PsyBorg
Wake up! Time to fly!
What is the switch range you are using? Since safe is looking for on or off normal position should be at 1000us and on should be 2000us. If you put it on a three way then using the middle position only goes to 1500us and wont trigger the safe feature.
If you are on a momentary check and make sure it toggles between 1000Us and 2000us same for a normal 2 way switch. If you only have a 3 way available then you have to make sure the middle position is set to 2000us
