Could you send me the plan or some video of your plane so that I can also make one?You could build yourself a nice 800mm flying wing, I have one with almost the same specs and it's very fun to fly!
I use exactely the same motors on my Dc3.
They were usen on a MPX Twinstar with a weight of 1,3kg ( 2,9 pounds ).
That means that with one motor you could fly a plane with about 700g ( 1,45 pounds ) of weight.
That´s a lot.
In your case i´d build 150% to 200% FT Spitfire, FT Corsair or FT Mustang ( i love warbirds )
But you should choose a plane, which looks good to you.
You can scale it up and down like you want!
I hope it was helpful for you!
Jetcrafter2000
Hmm. How are the travel throws on your elevator?
Have you checked your current draw? Believe it or not, a 6045 probably makes lest thrust with your motor than a smaller-pitch prop. The higher pitch could be bogging the motor down to the point where it can't make as much thrust as you need.
Because I don't have specific numbers on this motor I can't give you anything for certain, but I would defiantly try and measure the current it draws with that prop. Do you have access to a multi-meter or power analyzer?
I'm going to try 7×4 apc with that motor in a spitfire .that plane is pretty light .it should just Cruze will see🤙Hey Folks,
Jumping in because I was thinking of putting this same motor into an FT Spitfire. I was thinking a 7x6 prop with a 30a ESC (or I could do a 6x4). I've got other motors that would work, but I got this one when I knew a lot less about motors and planes and I'd like to actually use it.
Thoughts?
Doesn't the Spit have a 48" wingspan? Kind of think that motor is a bit small for the spitfire. I think I did a 2218 1150kV in mine. If I really wanted to use that motor I might reduce the plans to 75% of the original. I don't know what the flight characteristics would be, but it would be pretty snappy with a 2212 2200kV motor.I'm going to try 7×4 apc with that motor in a spitfire .that plane is pretty light .it should just Cruze will see🤙
