power 46 in a MS Corsair
leaded50
Ideal for 40- to 46-size airplanes weighing 4 to 7 pounds (1.8–3.2 kg)
Ideal for 25- to 40-size 3D airplanes up to 5 lb (2.2 kg)
It seems should be a pretty good powerhouse, for even close to twice the weight. 1:1 or more power to weight ratios is unrealistic as scale flying.
Dantheglassman
In simple terms is that a yes, or no?
Would one of the monster planes be a better fit?
Maybe the monster spitfire.
Thanks Dan
leaded50
a Master Series style plane would never reach the weight of 1.8 - 3.2kg by normal build, far lower... so yes, its a yes, it will even be perhaps "overpowering", a fast one!
leaded50
its gonna be big though.... 50 x 50mm.. thats even more than the FT powerpod, so you probarly need adjust the pod/formers, or make another motormount.
Dantheglassman
like this one?
