Marty72
I have 4 working FT planes currently, all have the same basic receiver and ESC. One of the 4 planes works fine except if you shut down the transmitter before disconnecting the battery from the plane (throttle is off and in cut off position), it will run the prop at a very slow rpm. If I turn the transmitter back on, the prop shuts off. I have a throttle cut switch and use it, but even with it on before I disconnect the battery, I get this slow prop spin. What is causing this? I have all the planes set up the same on the transmitter (as far as I know). I've tried re-calibrating the ESC, but that doesn't seem to work.
I'm sure someone here knows........what have I forgot or done wrong?
Thanks,
Thanks,
