bennyflint
Hi All,
My son (6) and I just assembled the FT Freighter and went to take for a test flight. We're able to bind the transmitter just fine, but when it gets to about half throttle, the motors stop running, and the led on the receiver starts blinking to, I assume, indicate a problem. It repeats two rapid blinks followed by a short pause. I can turn off the transmitter and receiver and re-bind them, but the same thing will happen again. Only twice have I been able to get it running at full throttle, but I don't know why it worked in those couple cases.
Interestingly, if I run the throttle just below the point it shuts down and then move the right stick, it also shuts down. This kind of makes sense because it uses differential thrust to turn so one of the motors speeds up quite a bit.
Has anyone else experienced this? Could I have a bad board? Battery is fully charged, btw.
Thanks in advance for you help,
-Ben
-Ben
