g828
Stickman
Hi, just thought I would post some photos on my conversion of the HiTec Hawkeye chuck glider sold by Horizon Hobby into an RC glider.
It is a simple conversion:
Top View:
I used rudder and elevator only
Front View:
I increased the dihedral to about 7 degrees on each wing
Internals:
Servos are 3.7 gram servos from Hobby King. The receiver is a Hobby King 3 channel receiver. The battery was a 2S 180mAh Nanotech battery. I dremeled out spaces for the servos, batters, and receivers. The BEC is friction fitted to the already made compartment on the glider. I use little velcro pieces and tape to hold down the canopy.
A little extra note, the weight that was used to balance the stock glider was a metal ball (maybe a lead ball?) that weighed 20 grams. My electronics weighed 40 grams.
Side View:
I cut little notches in the canopy for the servos to move freely.
Another note: The canopy does come off without having to cut into the foam. It is friction fitted onto the plane. But you will need a Popsicle stick to break the weak glue and free up the canopy.
Side View of the tail:
Just showing you how I attached the control horns and secured the music wire.
Thanks for taking a look at this thread!
I will try to get up a video when I can.
Top View:
Front View:
Internals:
Side View:
