I wanted to make a smaller version of the 810 and I went and start I resized the tile plans but when I printed them out they were full size Does anybody know how to resize them so they print out smaller?
when you open your print dialog window you should see a "scale" setting, select "custom" and then type in the percentage you want. just remember that you are still using the same "scale" foam so the score-cut channels will need to be adjusted so your folds will match.
