Rotor Bones Yaw mechanism question
klonaton
Have any of you found your Rotor Bones yaw mech is wobbly? Seems like the parts don't fit perfectly (specifically the brackets that hold the dowel and the pivot axel). I'm wondering if it's advisable to use any glue on there to firm it up. My pivoting motor is wobbling all over the place and I'm worried it's going to get unstable at higher speeds.
xuzme720
Dedicated foam bender
I was going to ask the same thing. I don't have any tilts since mine are quads and hexes, but those fit very tightly together with no slop. My only issue so far with the Rotorbones is my own doing. I was getting vibration in the mount but I was using motors that were much larger than they are rated for.
FlyingMonkey
Stuck in Sunny FL
Admin
#4
Take some pictures, post them here, because that doesn't sound right at all. Mine was a very tight fit, everything is super snug, even after many crashes.
klonaton
#5
Here are some photos. If it's unclear, the loose parts are the ones attached to the dowel, not the pivoting upper deck. photo 3.jpg photo 2.jpg photo.jpg
StoneKap
Executive Producer
Admin
Here are some photos. If it's unclear, the loose parts are the ones attached to the dowel, not the pivoting upper deck. View attachment 11695
Your wood dowel is definitely small. You shouldn't be able to fit the servo wire through the opening (where you have it.) It's designed for 1/2" or 13mm wood dowels. I'm sure you can still make this work though. Maybe add a skim coat of hot glue to each side of the wood to build it up. This might be enough to remove the slop.
Cyberdactyl
Misfit Multirotor Monkey
#9
Another shim method that works great with wood booms is to take ordinary wood glue and wet a strip of old t-shirt the width of the opening. Three or four wraps would give the boom an additional 3-4mm of cross section in each dimension. Of course, let the glue set before re-assembly. :p
Wrapping with wetted wood glue is also a great repair method for a cracked wood boom.
