Two weeks ago at an indoor fly-in I talked to a guy (forgot his name - not good with those) who converted a re-Run chuck glider from Stevens Aeromodel into a radio controlled flyer with electronics from a busted up Champ UMX. And I just happen to have been gifted a busted up Champ UMX recently. Serendipity strikes!!
The main points of the conversion are adding a pylon motor mount above the wing with the motor hanging forward to give the propeller plenty of clearance in the cut-out section of the fuselage. The receiver brick gets recessed into the side of the body (it's plenty thick) and some slicing and hinging create control surfaces on the existing tail section.
So the kit arrived yesterday, and sanding and glueing is coming soon. Just need to find an old floppy disk for hinge material...
