willwalk93
willwalk93 submitted a new resource:
Slow Stick files for landing gear mod and 340 size arrow (0.300") - flat carbon gear mod and versions of original CAD with larger arrow hole
Read more about this resource...
Here are some files for the s250 slow stick made from a 340 carbon arrow. These are sized with7.8mm holes to fit a 7.6mm/0.300" OD arrow shaft with material shrinkage and clearances. Printed in PLA and PETG on a creality K1, 2 walls, 10% infill. I'd recommend printing the motor mount from petg so it doesn't melt if you push it on 3s.
I only added the 3ch servo mount, as i put the aileron servos directly on the wing.
The motor mount is my own twist on the original so it could fit a third...
