Resource icon
Part Slow Stick files for landing gear mod and 340 size arrow (0.300") 1
Please log in to download
Type
Here are some files for the s250 slow stick made from a 340 carbon arrow. These are sized with7.8mm holes to fit a 7.6mm/0.300" OD arrow shaft with material shrinkage and clearances. Printed in PLA and PETG on a creality K1, 2 walls, 10% infill. I'd recommend printing the motor mount from petg so it doesn't melt if you push it on 3s.
I only added the 3ch servo mount, as i put the aileron servos directly on the wing.
The motor mount is my own twist on the original so it could fit a third screw.
The landing gear has integrated ESC holder tray and is made to use 5x1mm flat carbon for the gear and 2.5mm carbon rod for the axle. There's a spot for an M2 screw to hold the axles. you may need to open it up with a 1/16" bit if it doesn't fit. Pic of landing gear attached.
Author
willwalk93
Downloads
29
Views
1,288
First release
Last update
Rating
0.00 star(s) 0 ratings
