SP0NZ submitted a new resource:
SP0NZ STD Control Horn - FT Style Standard Size Control Horn
Read more about this resource...
This control horn is designed to work with most standard size Flite Test foam board RC model aircraft. The three push rod holes work with standard Flite Test push rods (.039) or can be drilled for use with E/Z connectors. I increased the thickness from the standard FT plywood control horns (.063) to 2 mm (.079) for a little added strength.
Settings:
My Printer: Anet...
