SP0NZ STD Control Horn
Part SP0NZ STD Control Horn 1.0
Please log in to download
Type
This control horn is designed to work with most standard size Flite Test foam board RC model aircraft. The three push rod holes work with standard Flite Test push rods (.039) or can be drilled for use with E/Z connectors. I increased the thickness from the standard FT plywood control horns (.063) to 2 mm (.079) for a little added strength.
* If you like this resource, please rate it. Thanks - SP0NZ
Settings:
My Printer: Anet A8​
Material(s): PLA​
Rafts: No​
Supports: No​
Infill: 100%​
Layers:
Height: .2 mm​
Top layers: 2​
Bottom layers: 2​
Perimeters: 4​
Author
SP0NZ
Downloads
178
Views
1,607
First release
Last update
Rating
5.00 star(s) 2 ratings
More resources from SP0NZ
Latest reviews
These are perfect. strong and light. Used the suggested settings.
These are nice control horns.
