throttle from the center
Shurik-1960
Hi..With the throttle handle trimmer, make sure that there is an extreme down position. Further..
Calibrate the throttle stick : 1. Turn on the transmitter with the throttle knob turned off to the maximum , 2.Connect the receiver with the motor to the battery supply 3. The engine will beep 3 times- remove the throttle stick at the minimum. All.Calibration is complete.
TEAJR66
Flite is good
If your throttle is 0 at center and turns the motor one way when moved down and opposite direction when moved up, your ESC is in bi-directional mode. Find the documentation for your ESC and follow the instructions for changing modes.
a.shvayakou
Thanks, it worked
