Hi!
After reading some threads here and there, and after some experiments, I've decided to build a 2nd TT with some modifications:
1. H and V stabilization have moved on the top of fuselage in order to align elevators and wing.
2. Servos are rear centered and outside of the fuselage in order to leave a plenty of space inside and to shorten rods.
3. Nose will hold the reinforced power pod from Hai-Lee for better impact resistance.
The tail is ugly but hey, it's actually not a beauty contest.
As I said, it's all about testing on the go, I'm using an already cut FB of the original design. It's somehow a limit, but it's a very reliable base.
I've seen a mod about wing attachment coming from inside the fuselage through square holes (rear side), I still have to figure out what could fit the best as 1 part of nose piece fixture / wing attachment.
From your experience, is there any obvious rubber band design to avoid? Over-crossed, too straight, tearing rhe wing, ...?
I will certainly add small reinforcement on the wing where rubber will pass.
