hdodevski
Greetings all.
I have a question. I want to be able to use the x6b reciever on a plane and that would require a pwm output for the servos. The reason behind this is that i would like a telemetry reading(which the x6b has integrated) and i would like a smaller setup, since the ia6b and ia10b are quite bulky, and require the external flysky voltage sensor( FS CVT01). Now if i connect the signal wires of the servos to the reciever, i would still need to power them from another 5v source, and this seems like too much of a hassle for me( i would probably need a pdb, no?). The other option is by using a ppm/sbus to pwm converter which seems much more convenient, and i wanted to ask if anyone has already tried that option and if it worked for you? I will post pictures of the converter as well. Also open to any other suggestions and ideas.
Cheers.
Cheers.
