• NOTE: The forum is currently undergoing a planned upgrade. Certain content or features may be missing or limited until the transition is complete.
Variable thrust, On a Mighty Mini Guinea.
ElectriSean
Eternal Student
Should be doable as long as your Tx can do mixing. 2 channels for motors, 1 for elevator and 1 for ailerons.
Paracodespoder
Spectrum DXe
For that radio differential thrust is not possible (I don’t think), but it is possible if you get a V-tail mixer . Plug one lead into the throttle and the other lead into the rudder, then plug one esc into one port on the mixer and the other esc into the other port. Swap leads as necessary until you get it working properly. I use one on my ft super bee as the dx-6i also does not have the correct mixing for differential thrust, works great for me (y).
