I'll try to give as much information as possible, but I'm somewhat of a noob here so I built the Bloody Baron over the summer, and it's awesome. I love it, but I recently looked into making it a bit faster. I posted on a different thread* about specifics, and I got a really detailed response telling me exactly what to get. So, as recommended, I bought an NTM 28-35 3000 kv motor, a 50A ESC (a brand wasn't specified so I went with durafly), and a 6x4 prop. I decided to use the same battery as before because I didn't want to buy anything I didn't need. I'll probably end up getting something bigger eventually, but for now it's a 20-30C 2200mAh 3s. Anyways, the problem is when I get past about 3/4 throttle, the motor does something that I can best describe as twitching. It seems to suddenly cut out for a split second but then goes back to the speed it was previously at. The frequency of these "twitches" increases as I approach full throttle. It's important to note that I have not actually flown with this setup. I've only tested the electronics on the ground without the prop attached. (maybe this won't happen with the additional load of a prop?) Something I have noticed is that I test this setup with a partly charged battery, this doesn't happen. But when the battery is fully charged, it does happen.
Any advice is appreciated.
Thanks in advance.
different thread* http://forum.flitetest.com/showthread.php?37001-Changing-electronics
Thanks in advance.
