Have you ever been unable to find that accessory to finish that urgent build, (normally just as the weather breaks and tomorrow will be the best flying day of the year? You know that you have the part but for some reason you just cannot locate it! You could spend an inordinate amount of time searching fruitlessly for it, (especially if your workshop is arranged like mine). You could jump in the truck and make a mad dash to the local hobby shop hoping that they have stock of the item you require. You could spend time searching for appropriate materials to hand make a piece to suit.
But then if you have a 3D printer all you need is the STL file and you can scale and print almost any piece you may require. Sure you can jump onto thingiverse and search for something that you can make work but then not everything there is free or designed for use with FB creations.
Herein I call upon all of those closet 3D creators to post their creations for use on FT FB Creations. I know that I have a number already! So I will start the ball rolling with something that no one else seems interested in and that is a temporary bungee hook which can be either taped into position or glued/screwed subject to your requirements. For tape or glue I recommend that you print it with a skirt to increase contact area, (not mandatory but some models I bungee launch are quite large, (up to 5 pounds weight).
Here it is:
More to come but I will wait to see if others wish to contribute first!
Have fun!
Here it is:
Have fun!
