I built this tricopter using the optimized template from RCExplorer.se. I like the coffin shape because it's easier to cut out and the hole placement is more durable. However, I then ordered the camera mount kit from FT and it is a tough fit. You can drill new holes in the mounts to fit the holes in your frame, but they seem to line up perfectly with the wire from the kit. It's doable, but just FYI.
So if you want to use this kit with an optimized tricopter template: You need drill your new holes in the mount kit carefully, then measure distance between your two sets of wires BEFORE you glue the wire-holding templates to the bottom section of the mount kit. You will need to disregard the lines that are laser-etched there. In my case, the two mounting brackets ended up being closer together than the original markings. And since I glued the wire holding templates down first, my wires will flare outward a bit and give me a little less room between the tricopter body and the camera mount. I'll post a pic soon.
