$10 Foam Glider PowerPack
Part $10 Foam Glider PowerPack 2.0
Please log in to download
My first attempt at this I have some downward angle added but that one lost the pod on the first crash. When I strengthened it I forgot to add the angle.
So Version 2 has 10 degrees of down angle (5 for the angle of attachment and 5 for throttle control.)
Also added is text to show servo size.
  • Like
Reactions: FeWolf
Update 16 June
I originally designed this for micro servos, but have had a request to design it for 9 gram servos as well. An issue also came up with the build area so I have also split the design at the battery tray.
So in summery;
PowerPod The original one - piece Pod for Micro Servos
PowerPod_Split Same as above, Split for smaller build areas.
PowerPod_9gServo One piece PowerPod for 9gram Servos.
PowerPod_9gServo_Split Same as above, Split for smaller build areas.
Any other input is welcome! (Let's see builds/Maidens!)
