FT mini scout snoopy figure
Part FT mini scout snoopy figure different snoopy version
Please log in to download
Type
Build Plan (PDF, AI, etc.)
this is a mini scout size snoopy build process
step 1 use a glue stick and glue the 2 snoopy on 2 pieces of foamboard
step 2cut on the black line
step 3 glue two half's of snoopy together( might want to reinforce the neck and scarf area, but is not needed)
step 4 cut appropriate sized slot on you ft mini scout. then attach Velcro to the bottom of snoopy and then Velcro in the slot on your scout.( best if you have wing in, you can glue him in but this way you can still flip the plane over and work on it without hurting snoopy:)!
also make Sure that when printing it is set to default otherwise it will be to big or too small
Author
mackaiver
Downloads
157
Views
956
First release
Last update
Rating
5.00 star(s) 2 ratings
Latest updates
  1. second snoopy
    follow the same insrtructions as before
Latest reviews
Very clever. Thanks for sharing.
Nice! Much better than mine
mackaiver
mackaiver
thanks
