Joe M
I've been wanting a smaller plane to fly at the local park and after finishing work on the Sopwith Camel there's been a plane-sized hole in my free time, so I'm building one of these in park-flyer scale:
I like this Richard Flasher scheme, very medieval.
I'll be building directly from the Bob Holman D.Va plans, scaled down from 59" (1:6) to 36" (1:10). These are awesome plans, and I definitely recommend them to anyone thinking about building one of these planes.
Link to plans:
https://aerofred.com/details.php?image_id=97244
I've got five sheets of DTFB left in my supply right now which should be plenty for a plane this size, even doing formers/stringers and sheeting the fuselage. I'll glue everything together with Gorilla Glue (white) and hinge the control surfaces with CA hinges using Gorilla Glue.
The plans have rib profiles for scale construction as well as thicker sections for better-than-scale (especially at low speed) flying, I'll build the thicker sections and I'll build the stab thicker as well, because foam.
Tentative Specs:
Wingspan: 36 in
Length: 28.9 in
Wing Area: 328.3 sq in
Flying Weight: 800g (28.2 oz)
Powerplant: 370W BL motor
WCL: 8.2
Propeller: 9x4
Power/Weight: 210 watts/lb
Maximum Speed: 45mph
Endurance: 15 minutes on 4S 2200mAh
I know the battery makes no sense for that motor/prop combo, but it's what I have on hand. I'll have to trim the throttle channel on the radio with a power meter to make sure that it doesn't exceed 370W or 31A at WOT. I'll lose some throttle resolution, but 15 minute flight time isn't bad.
Link to plans:
Tentative Specs:
Wingspan: 36 in
Length: 28.9 in
WCL: 8.2
Propeller: 9x4
