ProfessorFate
I've had a few strykers and wanted to make it over with foam board and aim for different characteristics. Strykers are nice easy goto foamies you can keep in your truck and fly after work somewhere. The foam blank can still be bought at Amazon or Ebay for $20, you add fins, motor etc. I just want one flies better
It will fly in any wind but stops penetrating and gets blown away after about 20 mph winds, and I did not try weighing it down with a heavy power system. But as stock, in some areas/conditions it nearly floats like a glider.
So I started looking at the arado 555 with goals of using a quieter 8" prop, 1250kv motor, 3s 2.6ah lipo.
Goals: better penetration and glide, better stability
The stryker has some funny angles that didn't make best use of the 20x30 inch foam board so you'll see in my drawing after some thought to arado leading edge I switched back to stryker flat form and only 2 places on the foam board to mark and cut straight lines.
7 and 4.5/16 Up on Left Side, 6 and 9/16 UP on the Right Side. See Drawings. And I start building on the bottom to to keep it flat except for shaping the LE bottom up a little for stability... a sharp edge makes some instability.
I'm referring to cutting out the Right Side. Mark a line from the Left 7 and 4.5/16" down to the bottom Right corner.
Go to Right side 6 and 9/16" mark and draw up to the top Left corner. This is the pattern for L and R.
So the one foam board is vertical, making 2 halves 40" wing span. Total needed is 4 sheets.
I could not find my wax paper, but after you apply gorilla glue you could put wax paper or teflon aluminum foil to make /shape glued joints as smooth fillets.
The stryker has 40 deg LE sweep and this one has 50 degree LE sweep and I'm trying all I can to make the top fast surface smooth to increase lift, including I might put servo link and control horn on bottom. Bernoulie lift likes the top surface as smooth as possible and wind passes over it fastest, creating that lower pressure that Pulls the wing up along with the higher different pressure Push the wing up.
I'm using regular gorilla glue as much as possible and Ross foam board because their paper sticks the best to the foam, dtfb just peals off too easy. Just in case I also cut paper out in small spots to help glue bond to everything. The wood is 2.7mm underlayment sheets 4x8 cut down to 1x4 foot, great savings much cheaper than midwest lite ply.
Near the center stryker measured 1.25 inches so all those measures on the sheet are the inside space 7/8 plus 3/8 being 2 foam sheets giving 1.25 inches thickness working outboard called in 8ths only
That wide blue foam holds the edge to glue the foam board. I'll make more in decreasing sizes outboard to tips and glue the foam sheet on top of these. The smaller ribs might be glued with a little extra height so they can measured compared and sanded. The outside tips max at 1/8" inside.
So with current airframe, lipo, controller and motor, the weight is 26 oz. The last Stryker, F27Q weighed 30 oz, I might be a few ounces over
Stryker F27 Q 3view top view BEST PKZ5680_a3-1 BIG 1400 pix. UP Straight copy.jpg100.5 KB · Views: 0 -
Stryker WS 48 LE 130 or 40 deg TE -- deg LINES Straight compare 37.5 to 48ws copy.jpg988.6 KB · Views: 0
Arado 44 inch 111.76 cm Lines 8 inch FLIP 9 SHEET 20 X 30 copy.jpg127.9 KB · Views: 0 -
