Mighty Mini Sea Duck
Horseman3381
At Flite Fest 2019 there was a gentleman who was flying around a 60% sea duck he had built. He didn’t have plans for it and told me he had just printed out a set of scaled down plans and “winged it” as he was building. Ever since I saw it, I knew I one day needed to build one.
Finally Last fall I decide to modify the plans and build one for myself. I have gone through 3 variations of the plane to date, and believe I have all the kinks worked out.
The plane flies amazingly. With A-pack motors it is super docile and a nice easy lazy flyer. If you put F-pack motors in, it can slow down and fly docile, or you can turn it up and easily do loops and rolls to your heart’s content. Both motor configurations allow for easy take-off from land, water or snow.
I fly the plane with a 3s2200 on F-pack motors with a 6 min flight I generally have a little over 50% battery remaining. When I tried to fly with a 3s850 and 3s1500 I had to move the battery pretty far forward to get the CG to balance.
Here is a photo showing it's scale. The middle one is the FT Sea Duck and the bottom plane is a 180% Sea Duck. The 180% is no longer with us as I tried to get a little too acrobatic not enough mistakes high. I will rebuild it this fall while fixing a number of design flaws, and post about it when it rebuilt.
Specifications:
  • 3’-0” Wingspan x 2’-5” Long
  • Building Materials:
  • 3 sheets of foam board
  • 2 popsicle sticks
  • 1 wood bbq skewer
  • 3 FT mini control horns
  • 2 FT mini firewalls
  • Y-Power harness (if using 4 channel receiver)
  • Up to 3 servo wire extenders
  • 4 channel receiver minimum
  • FT A-pack or F-pack Motors & ESC’s
  • (3) 5g servos
  • 5x3 3-blade props
  • 3s 850mah to 3s 2200mah battery
Plans can be found here: Resource Page
Build Notes:
When building the plane, follow the FT build video for the full-size plane. The only 4 differences between the Mini and Full-Size builds:
  • The wing spar is a single piece in lieu of 3 pieces. This should be mounted with the U spar in the upright orientation.
  • The aileron servos are mounted 90 degrees from the full-size version with the wires facing the fuselage.
  • In the pontoons there are only single spacers on each side of the strut instead of double.
  • On the fuselage rear bulkhead, there is a partial depth cut line ¾” from the bottom. When installing this, do not glue above that line as with the small top hatch, it is tough to access/mount the receiver in this plane, so I left this as an access hatch for that purpose. It stays closed with friction.
The plans are laid out where you can install functioning rudders if you want. However, with the smaller nacelles it will be a challenge to fit the rudder and aileron servos in the same nacelle.
I designed 3D printed headlights and a nose cleat for the plane as those are iconic features of the Sea Duck to me. I have included these in the resource as a .stl file with the plans.
Design Notes:
When I scaled the plans to 60% I made the following changed for version 1.0:
  • Scale up/modify all cuts and folds to work again with the 3/16” foamboard.
  • Modify the size of the nacelles to work with the mini power pod.
  • Update the wing configuration to keep the same shape as the full size.
For version 1.0, the build went pretty easy by following the build video for the full-size plane. There were a few spots where some trimming /modifying was needed, but overall went together easy. The biggest issue was that when using the CG location from the full-size Sea Duck, the plane was very tail heavy. The CG ended up needing to move forward 3/8”.
Version 1.1 contained the following updates:
  • Updated the location of the CG indicators.
  • Increase the size of battery tray to allow for battery to be mounted further in the nose.
  • Update the wing spar to a single piece.
  • Added hinge point on rear hatch to allow for easier access to receiver.
Version 1.2 (current) contained the following updates:
  • Reconfigured aileron servos cutouts to allow for easier/cleaner installation.
  • Modified the size of pontoons for easier/cleaner build.
iceking1152
Very neat! I took interest in this as I believe seaplanes will be a huge focus of this hobby for me. I've got all my parts ordered to build this, it will be my first FT build, first build in general, and my 2nd plane (first made it ~25 flights before becoming stuck in a tree). I've watched most of the build video, but I still have a few questions:
  • "mounted with the U spar in the upright orientation", does this mean the spar sits with the open side facing the underside of the wing? So if the plane is sitting normally on its belly, the spar would be "U" instead of "n", just like it does in the video for the center section? In the full size kit, I would refer to the outer spars as being in the "n" orientation.
  • I've watched both FT videos on waterproofing: the foamboard video and the electronics video. I was just wondering what you personally did, and found the most effective?
    • Which foamboard did you use? Regular, or waterproof?
    • Any comments about the polycrylic process if you used it, specifically if you used it or "minwax" on the wings?
  • In general, any comments or tips that you may think would be helpful.
Horseman3381
I'm glad you are taking interest in this plane. It is my favorite to fly, so I hope you enjoy it.
  • When I say mount the u-spar in the upright position, that means when the plane is sitting upright, the U should have the open side facing up for the entire length of the spar just like the outer spars are in the video. As this is a single piece spar the inner portion of the spar is not inverted like in the video. The spar has cutouts in it for the pontoon boom and aileron servos that will align with the openings on the bottom of the wings just like in the video.
  • I mostly build using waterproof foamboard, and have not experimented with trying to waterproof regular foamboard. I have built this plane (and several others) out of regular foamboard, and with a simple coat of Rustolium, as long as you aren't flying it off water, it will be fine. I have flown many planes off water and never bothered waterproofing any of the electronics, or had any issues with them.
  • The Sea Duck was my first FT build. The biggest tip I have is watch the build video through at least once before you attempt the build. Then as you are doing the build, make sure not to get ahead of yourself while building. As long as you follow the build video, things should go good.
Good Luck! Let me know if you have any more questions.
iceking1152
Thanks for your reply! For this project, I got some water-resistant foam board and I plan to be mostly using it flying on and off brackish water, so I just want to be extra careful. Did you use clear packing tape on the wetted surfaces at all? I’m thinking that I’ll sand, prime, and paint it, then put minwax water based polycrylic coating over the paint layer. Lastly, packing tape on the wetted surfaces.
Edit: I am also considering doing an epoxy and fiberglass layer over the wetted surfaces instead of packing tape. Maybe forego the minwax if I do that? Thoughts?
