After doing alot of number crunching with prop, motor, and weight combinations, it seems after you add the extra weight and current draw of 2 motors and arms into the calculation, 6 motors are more efficient than 8 at least with the motor, prop combo I have chosen. The next decision to make was whether to go with 22mm carbon fiber tube or 19mm box section aluminium arms.
Now you would think it would be a no brainer with the CF tube weighing 40g and the drilled out aluminium 75g, but after you consider the CF arm needs 4 clips, 8 nuts and bolts and a CF motor mount and the aluminium only needs a ply motor mount and 3 nuts and bolts, there's only a 6g advantage to CF. If you then add in cost and possible radio interference issues of CF, then I think aluminium is the way to go
