L Edge
I wish you would add 2 items in your quest of LOS and the cause.
I hope you would add that in your instructing someone or a pilot that is having a LOS, move the TX to another position to possibly regain signal. (Don't let them point the radio at the plane.) Being a member of 3 clubs, it has worked once or twice and saved big bucks. That's for all radios systems.
Secondly, Spectrum has a flight log that records individual antenna fades, failsafes, frame losses that you can use with over 9 RX's. I have used this in proper positioning a glider Rx where I did have antenna fades (added satellite to resolve) at 1700 ft . Now it comes down and every time I have zero's .
I own a composite 50 cc gasser worth big bucks where the flight log solved my problem of LOS. Ended up moving a satellite rx back 36 inches and now it records zero hits. Can't ask for anything more.
Should get one and explore to see if it can resolve LOS problems on others with Spectrum equipment. Usually it is the positioning and distance.
For your reading.
https://www.horizonhobby.com/spektrum-flight-log-spm9540
For your reading.
