PeterGregory
CrossThread Industries
I am sharing my tale of non-success - but I believe I will be successful, eventually.
You can see a picture of a classic OK Cub Diesel .049 I bought on eBay.
It either was never run, or it never could run - ha.
Very pristine, it is about as old as I am - the 50's.
I took it out and set up the test stand at noon today, thinking I would have run it and cleaned up in about 1 hour.
That plan was not to be.
For longer than I like to admit, I flipped that diesel with great expectation that the next flip would be the one where it would kick off and scream.
I learned a lot, and I think I have what should be the correct compression and needle valve "NV" setting.
There were burps & purrs for a second throughout my trying but I could not get it to catch.
What I learned on this tiny, responsive engine was to keep my left hand on the compression screw. The engine did not want to run "dry." I found I was flipping forever with no kick when it didn't sound juicy. After you prime either right into the exhaust port or into the front intake, it would sound very juicy. You have to back off the compression because that extra fuel causes detonation before you reach top-dead-center (TDC) with the piston. You can feel the prop kick back before you push the prop to the "downside" of the stroke. It is a lot like fishing with worms of bottom bait, when you feel the tug-tug-tug of a fish. The bump-bump-bump of the juicy detonation tells you to increasingly ease the compression as you keep flipping, and at a certain good point the engine will actually fire correctly for a while, then it is time for more juice.
I just couldn't get the engine to draw its own fuel into the nipple on the intake port. I had great expectations with each flip, but wore my arm out (again.) I do love the pursuit of the "sweet spot" for the engine, though.
I will tell more about what the problem was once I hear back from some inquiries I put out on the internet.
Most of all, i will pick an outerzone.co.uk plan to put this into and do a build log, here.
There are a bunch of things about these I diesels I do like, the nostalgia being one of the biggest factors.
Sweet Heap - British from Aeromodeller
