Freaky_1
old headcase
Anyone care to proof some PDF files?
Having built "project Thunk" as far as glide testing, I went ahead and plotted everything out for the 3.5" wide fuse version on Sketchup.
I've only played with the software a little at this point and would like to have someone minutely interested or extremely bored to proof the files for me before I figure out how to make them a printable image. I saw a few posts on the topic of making printable images, but haven't taken the time to figure it out yet. I'm more a one step at a time type.
This is not flight tested as I have to hold on to what cash I have at the moment. She still needs servos, some battery wire, control rods and a little air to surf on. She's glide tested great as is, but in truth, the plans are only for the fuselage as It's intended to take a wide variety of wing designs.
The plans are intended to be hinged between the "cabin" and "tail boom" with a simple hinge on one side and a simple mechanical fastening system to lock the halves together. The prototype is done this way and I expect to do all mine this way, but it can be glued together in one piece, or made bolt together as "The Tractor" or other methods.
Anyhow, if you're game, I'm attaching the files in a zip below.
For that matter, feel free to build it if you have any use.
View attachment thunk swf for share.zip
PDF version
View attachment Thunk1 Final.pdf Sheet 1
View attachment ThunkEmp printNcut.pdf Sheet 2 OLD VERSION of sheet 2. NEW coming.
Thanks,
Frank
-----\/ ignore the file below until some kindly mod deletes it and this line as I have no clue how to. \/---
PDF version
Thanks,
Frank
