DutchRC
Howdy people
I spotted this reasonably new FPV set from Aomway the other day, soooo I ordered it.. This is my first look at an Aomway product by the way..
It's a bit hard to really capture an FPV-feed, but I hope this video gives you an impression of what is/does..
In words: I am quite impressed by the video quality of the cam!
Linkje this cam + transmitter: Aomway WDR 700tvl cam + 200mW VTX
Specs Camera:
Video Format: PAL
Pick Up Device:1/3"COMS
Picture Elements: 976(H) x 496 (V)
Output Power: 23~24dBm
Operating Voltage: 7V~24V
Power consummption:120mA
Dimension: 22mm x 20mm
Weight: 35g (includes camera, transmitter and antenna)
Lens: 2.1mm
TV system : Pal
Horizontal resolution: 700TVL
S/N Ratio:>=45d
Sensitivity: 10.8 (V/Lux.sec)
Scanning system : 2:1 interlace
Specs: (VTX)
Frequency: 5.8GHz
PowerOutput: 200mW
Modulate: Wideband FM Modulate
Video Format: NTSC/PAL
Output Impedance: 50 Ohm
Channel: 32CH
Supply Current: 190mA
Operating Temperature: -10~85 Video Band Width : 0~8.0 MHz
Audio Carrier Frequency: 6.5MHz
Video Input Level: 0.8~1.2 Vp-p
Video Input Impedance: 75 Ohm
Audio Input Level: 0.5~2.0 Vp-p
Audio Input Impedance: 10K Ohm
Connector: SMA
Dimension: 26mm x 23mm x 8mm
Weight: 6g (without antenna)
Specs Camera:
Video Format: PAL
Lens: 2.1mm
TV system : Pal
S/N Ratio:>=45d
Specs: (VTX)
Frequency: 5.8GHz
PowerOutput: 200mW
Channel: 32CH
Connector: SMA
