APM 2.5 compass calibration
Johan
Hi all,
For future projects I've got an APM 2.5, with internal compass and external GPS (the Mtek one, flashed to v1.9 firmware).
I just did a (living room) Compass calibration dance, well several to be precise.....
But the calibration results vary a lot (and I really mean a lot) ..
I roughly know where the North is and I also know an iPhone 5 Compass is not too accurate, but when calibrating the APM 2.5, I see deviations between 10 degrees up to 80 degrees (!) difference (at that point I could tell it was not the iPhone that was way off).
Are there any other APM 2.5 users that experience the same?
Is there an -apparently secret- way to perform the "Calibration dance" ? :)
I now think I should have left it where it was only a few degrees off..
PS, there is the auto inclination setting, but it differs from when I actually look up the inclination for my location.
Any ideas on that?
PS: I kept clear of metal and other obvious magnetically interference (Including the phone etc)
Tritium
Amateur Extra Class K5TWM
The compass is VERY sensitive. Any magnetic sources will have an effect on your "dance" results. I have too many BIG neo's in my house (home brew wind turbine builder) so my dances take place outside where the flying will occur. I always use the looked up declination settings on mine (APM 2 and Arduflyer 2.5)
Thurmond
Johan
Thanks Thurmond,
I'll keep that in mind !
Next 'Dance' will occur outside (at a time the neighbors will be indoors for dinner I hope:), well give the autumn-like weather these days in the Netherlands that should not be a problem, then again flying is ...
