Awaiting Delivery
Brian fred carr
Site Moderator
This should be here Thursday...... 12 Channel 900Mhz Tx/Rx FPV video system with Sony CCD camera.
Here's a great First Person View system, it's a complete set, all you'll need is a small 3 cell LiPo battery pack to power up, plus your own video goggles or video screen.
The 100mW system is legal in most countries, but please check before buying that it is legal to use in your specific location.
You will be able to use either 35Mhz. or 2.4 Ghz. radio gear with this system without suffering interference problems.
Unlike other generic systems, a wiring loom is included with the camera so that the Tx. and camera will be compatible and on the same voltage.
Included:
1 x SONY CCD 1/3inch Camera
1 x 900Mhz 8 channel Video Transmitter (100mW)
1 x 900Mhz 12 channel Video Receiver
Camera specification:
CCD sensor type: 1/3 color SONY CCD
Pixel: 500(H) x 582(V) (PAL)
Scanning system: Interlaced scanning
Synchronization: System: Internal synchronization
Horizontal resolution: 420TV line
Minimum Illumination 0.01LUX/F1.2
DSP+CCD: CXD3142R+405AK
S/N Ratio: 48dB
Gamma Modification: 0.45
White balance: Auto
Auto backlight compensation: Auto
Lens: 3.6MM
Audio: No
Input voltage: 9~12.6V
Electric current 80MA
Electronic Shutter: 1/50 (60) ~ 1/100,000s
Video output: 1.0VP-P composite video
Operation Temp.: -20~50
Size: 38 x 38mm
Flight time: Approx 60min/100mah using a 3 cell LiPo pack (not included).
FPV Tx. Specification:
Channel: 8-Ch, AV synchronization
Power: 100mW
Input voltage: 12V
Weight: 29.9g
Frequency: 0.9G 0.910G,0.980G,1.10G,1.040G
The only thing I don't truly understand is the wiring loom, it says it will run off the tx...? do they mean the
camera will use voltage off the tx once it is connected to the battery?????????
all replies appreciated
