Foam Addict
Squirrel member
It's, ALIVE!
My first rewind project works!
It's a 2306 stator size Hobbyking motor, wound y with 15 turns of 26 gauge Newbie wire from gobrushless.com
It draws .86 amps unloaded at 7.2 volts, and it's KV sounds high, but I'm not sure.
It was originally a 2000 KV motor when terminated delta, but as I don't have an RPM sensor, I can only guess based on the fact that I have the same number of turns, and it has .58 times the KV, that it is a roughly 1200 KV motor.
