Baby Bugatti 700m
#22
I thought I'd give everyone an update. I flew the bugatti on the 800mAh 3s battery today, and it flew so much faster. I'm very happy with how this plane turned out: very fast, very nimble, very responsive.
One thing that caught me off guard the plane rolling right. I had to trim my ailerons to the left 50 clicks before it leveled off. The plane does not have any significant balance issues (weight-wise) about the roll axis. I've always had to put some left trim, but with the new motor/battery combo, I definitely needed to add more. My motor spins the typical direction- I wonder what is causing this.
#23
It occurred to me that most people may not have access to a laser cutter, so I repackaged my plans to be printable on 8.5"x11" paper. I've added the file to the original post.
#25
Lawrence,cool build,do you have any right thrust built in? If so you may want to zero it.
how bout making a 700mm kit for us ......cnc foam cut?
tnx
My motor is mounted straight on. I never give my planes any thrust angle.
What do you mean by a kit? The plans are posted. I've never cut foam board on the CNC (I have milled wings and fuselages). Laser is faster, although the foam shrinks at the lasered edges.
#26
700mm Bug
Sorry,I meant to say Laser cut....Yeah it will melt a bit on the edges...The FT kits are all slightly shrunk at the edges according to the pics I've seen... ...I usually rely on the trusty sharp blade in my utility/xacto knives
Well time to print your plans and get cutting..
Cheers
#27
Cheers
If you live in the Portland area, you'd be in luck. I fly with a group of guys and often help them laser cut flitetest kits out of foam board.
