Help! Battery location
FDS
It attaches to the UNDERSIDE of the power pod, via sticky Velcro, like all the minis.
FDS
Don’t forget to CG your plane and don’t work on the electronics with a prop on, ALWAYS remove the prop when working on the planes electrics.
I agree with @FDS, battery placement is critical to CG. A nose heavy plane fly’s poorly, a tail heavy plane flys once.
  • Like
Reactions: FDS
Brett_N
There are Round Circles on the plans for the CG.
My recommendation is and always has been to put a strip of velcro down the underside (or side) and velcro on the batteries so that you can adjust it at first to get close to that CG point. Then run a BBQ skewer through and use a Velcro / Rubber Band Combo.
Slightly nose heavy is better than neutral or any tail heavy. (Unless it's a 3D plane....)
  • Like
Reactions: FDS
