Soooo....yeahhhh...bent a shaft...is the motor toast or is there a magical way to fix it? I bent it back to "close" to straight but there's still some angle and vibrations for sure. Thoughts?
What motor is it? You may be able to find shafts for it. I have replaced bent shafts in two of my motors. It's much cheaper than buying a new one. I buy spare shafts for most of my motors, and have not had any issues replacing them.
Have you tried that with DT750s? I'm not able to get the shafts out...
Now I'm running bolt-on prop adapters, so the chance of bending a shaft is way lower
No. I replaced the shaft in a Turnigy D2826-10 1400Kv. The shafts don't come out easily. I picked up a cheap 1/2 ton arbor press from Harbor Freight (about $30 with 20% off coupon). That's what I used to get mine out. I have had to replace 3 shafts so far (2 times in one of the two motors). The shafts cost me about $1 each.
I have a FMS P-51 800mm that bent a 3mm shaft. I made a new one out of a slider rail inside a CD-ROM drive using a Dremmel tool. There are a few Youtube clips on how to do it.
