It's close enough English
Since you can't test it for yourself it would be a good idea to go with what you know works already. If lifting tail surfaces are unfamiliar territory then I would skip that and go with a simple design. I would, and only if I was you, and this is just my opinion, is a biplane design give a few rules of wing dynamics, prop in the front, balance with an extended tail that only stabilizes the pitch and yaw axis, no lifting.
The wings will be your 1 meter on the diagonal in wingspan, with a 200mm wing chord, flat bottom with a 30mm maximum total height of the cross section of the wing, the last 100mm of each wing tip is under cambered. Two wings built like this which will be removable from the fuse from the top and bottom of the fuse in a biplane configuration spaced 160mm apart from the top of the bottom wing to the bottom of the top wing. The CG should sit somewhere between 50-65mm from the leading edge, which is where the spar will be located in the wing. The horizontal stabilizer should be 250mm in span and the vertical stabilizer at 125mm in height. The fuse length should be kept inside the 1 meter diagonal length with the tail feathers, motor and prop attached, in doing rough head math will have roughly a total length of 800-850mm.
Does this sound about right to you?
