I ordered the following components.
These are being installed into a mighty mini P40. The plane is built and now it has come to the process of connecting the electronics and binding the radio.
As best I can tell from the sketchy instructions included with all the bits and pieces... the battery should be plugged into the speed controller. Then the servo wire from the speed controller should be plugged into channel 1 of the R88 receiver. According to the documents included with the R88 speed controller to enter binding mode you hold down the bind button on top of the R88 while plugging power into it. The R88 should then begin a process of blinking several times cycling through each supported protocol waiting for binding to actually happen from the transmitter. My speed controller does nothing. No blinks no nothing like it is getting no power.
I grabbed a multi-meter and checked the voltage of the +/- on the servo wire and it is around 5.4v. So should be good... I also checked the voltage of the signal to ground and it is around 3.3v. So the speed controller is providing power.
Not sure if I am missing something or if this is mis-wired.
I also saw a YT video that said the R88 does not blink at all when not bound and will blink during the process of binding. So I tried doing the normal power up while holding the bind button and then attempting to bind it with the Zorro transmitter. It did not bind and I did not get any blinking lights on the transmitter during the binding process. I was using the FRsky v2 /D16 setting. Not sure if this is right or not. (poor documentation)
Anyways any assistance that can be provided would be appreciated.
| Tattu 850mAh 11.1V 75C 3S1P Lipo Battery Pack with XT30U plug | 4157123321 | 1 |
| RadioMaster Zorro 4-in-1 | 4157123292 | 1 |
| FT Power Pack F Radial v2 | 5114051212 | 1 |
| RadioMaster R88 Receiver V.2 | 5302051351 | 1 |
