OlliePackman
I know we all fly planes here (and this is in the fun and distractions category) and no one might be able to help me but might as well put the questions out there...
My plan is to build an RC boat out of the spare components that I have from crashed and unwanted planes just as something a bit different. There are some things that are different, but from my understanding, the systems are largely the same. With regards to an actual body/Hull (Airframe for plane people 😂) I am going to use replacement parts to an existing product which you can find in the next link. Please make note of size, weight etc. For the power system.
Hull - https://m.banggood.com/FT012-2_4G-B...-gb-en-mb¤cy=GBP&cur_warehouse=CN&createTmp=1
Canopy - https://m.banggood.com/FT012-2_4G-B...-gb-en-mb¤cy=GBP&cur_warehouse=CN&createTmp=1
For power, I want to use a 16mm jet thruster (or 2 if possible) found below along with a 2440 4000kv motor (also found below) and a 50a hobby wing skywalker ESC which I already have. If it is only possible to use one motor per ESC (?), then I will have one central jet thruster providing it will produce enough thrust to get a decent speed out of the boat considering size and weight (?). However, if there is some wizardry which I don't know about which means that you can use 2 motors (powering the jet thrusters) off of 1 ESC, then I will do this for increased thrust and speed. Not sure how much sense that all makes so I guess my power questions are:
Is the motor the right size for the jet thruster?
Is the jet thruster the right size for the boat?
Can you power two motors off of one esc?
Would you advise having one or two jet thrusters?
Jet thruster(s) - https://uk-m.banggood.com/1pc-16mm-...y=GBP&cur_warehouse=CN&createTmp=1&ID=6157193
Motor(s) (4000Kv version) - https://m.banggood.com/Racerstar-24...nnel&utm_campaign=Feb&utm_content=huangwenjie
ESC (which I already have but might need another if I need 2 jet thrusters) - https://m.banggood.com/Hobbywing-Sk...6ia4VUVh8F9g3HBMscToEdY8o85D1gPcaAg4XEALw_wcB
Also, I'm pretty sure I am limited to a 3s setup as the jet thruster says it is only rated for 6 - 12V (please confirm) so what 3s battery should I use? I'm thinking 2200mah 30C but I have 3200mah as well if needed - please advise.
I will be using a 9 gram servo for thrust vectoring and the rubber seals for the control linkage so water doesn't leak in. Also, the esc won't have air to cool it anymore as it isn't in a plane, so I was thinking of improvising a water cooling system with fuel pipe wrapped around the esc.
Finally, if there is anything else that I have missed then please point it out to me and thankyou for reading this giant thread and checking my stuff out. Much appreciated.
