Solved Mighty mini arrow compatibility check
JasonK
Participation Award Recipient
20a ESC with a motor that states it can pull 23A, doesn't look like a good combination.
otherwise, your items don't look to bad.. My experiance has been to use a separate BEC from the the one in the ESC for the FPV gear, else you will end up with a whole lot of noise from the servos in the video feed (so depending on your FPV gear, another BEC might be needed).
OlliePackman
I don't use the sound in my video feed and I just have made a little pod with a camera and vtx that uses the balance lead of the battery to power both which I can strap from one plane to another in 2 seconds
JasonK
not, not audio noise, video static.
if your using the balance lead off the battery, then your camera/vtx probably have their own BEC/regulator in your module.
