mach1 rc
After seeing Ben harber and Josh orchards Bugattis I knew I had to make one. This one will be running off a 2212 1000kv motor and a 40 amp esc not sure whether to go with 4s or 3s.
it will be probably be run on a 4s 1550mah or a 3s 1500mah battery.
now all I have to do is put in the wing servos and hook up the electronics.
this one will be swappable and has a 41ish wing span and a 40 inch length. Going to try to get it in the air this evening.
