building a glider
hello183
I took the glider for another flight, but it had an encounter with a tree.
Luckily only a portion of the leading edge between the ribs broke and I haven't been having trouble fixing it. It looks a bit crooked in the picture, but it is just the camera.
When it gets warmer, probably next year, I will take it to a bigger area where it hopefully will be able to reach some thermals and get longer flights. If I could launch this into a thermal and get it high up, it glides well enough that I could definitely lose it. I measured one of the flights and I think it got a glide ratio of between 16:1 to 20:1. It might be able to fly better if i change the wing incidence.
A dethermalizer needs to be very agressive, almost to the point of crashing to overpower the lift gained in a thermal. Typically, people try to cause a stalled spin which is gentle enough to not break things. Spoilers of at least 10% wing area might be enough, but I have seen thermals strong enough to carry porta potties away. Loosing your plane in a monster thermal is a rite of passage
hello183
It would be hard to cut off the control surfaces or the wing dowels, which are things I'd need to do to add a dethermalizer system like the ones in the video. But I heard of a pop up fuselage dethermalizer. What do you think about a system that disconnects the nose cone for the dethermalizer?
hello183
I was thinking that if I disconnected the nose somehow, the center of gravity would change and it would come down. But to not lose the nose I'd have to attach it with a string or something. Is there a way I could add a parachute while keeping the weight down?
danskis
Well the parachute was a dumb idea. In a large thermal it would probably make the plane go UP. Your idea is better
hello183
I was thinking of designing a bigger glider with radio control. I won't do that now, because I want to learn how to fly first. What carbon fiber tail boom would you use for a glider that is big, but meant to go quite slow? The wingspan right now is a bit more than 2 meters, and the fuselage is about 1.4 meters. I was thinking about one with a 10 mm diameter. I couldn't find any tube long enough online. Where would you look for it?
danskis
10mm sounds perfect. How are you going to get it in the air? Hi sart, motor, or throw it. A 2 meter glider is perfect for learning how to fly RC.
danskis
You have options with the boom. You can make a nose that goes from the back of the wing forward basically a box out of foam board or balsa or a combination of both. and use the CF boom for the back. Or you can buy two shorted booms and splice them together.
hello183
I was thinking about using a motor, but I may just use a towhook. I was going to build a balsa pod in the front, but even with that, the boom would need to be 95 cm. I could only find 50 cm booms online. How could I splice booms together?
Also, should I put this discussion in a different thread?
There's also fishing rods and arrow shafts. The arrow shafts have a common diameter that uses a readily available carbon shaft as a splice, Saw a 9 ft fly rod at the local Goodwill for $5 that needed the ferrules taken off the lower half
quorneng
I use tapered glass fibre fishing rods as tail booms.
ct that there are tapered actually, The fact in part, matches the bending forces so reduces the deflection for a given weight. With a "V" tail the micro servos are mounted in each tail plane and the wires run up inside the boom.
