Here is a fun project to do that is real easy to build.
Simple to make--make circle,re-inforce dia, add vertical piece(rudder at end), glue 2 carbon rods and vertical stabs, setup cross piece for elevons . Mount motor/prop and all electronics up in nose.
If enough people are interested in building one, I will do a layout of the dimensions.
Oh yes, once I made the barrel, then I was able to roll it!! Yes, it will even loop. 1:23 if you watch close, head camera cheap
Not only designed a one barrel, designed a 2 barrel plane called "Double Trouble". Will put that up another day.
