the rc project
I’ve actually done a few flights with one of my test models to specifically test flying backwards, it proved to be a non issue. Likely because the tail motor compensating for the nose up push from the elevator. This is probably a far bigger issue on bicopter configurations. Also I believe the wing does go to zero degrees for forward flight but not on the ground because of prop clearance. This won’t be an issue for me because a scale size prop would be a 11in. This is twice the size of what ill be usingIf you back up from hovering with horizontal stab down, that's a no no.
