L Edge
I wanted to design a plane that can STOL, fly in a small area and handle gusty winds and yet be stable in all conditions.
So to meet this goal, I am going to design it around a Cub(bish) which I haven't tried. Here is what I am doing to do for mods.
1) Chose full length ailerons to also to act as flaps. (Roll will be a handful.)
2) Endplates- With the endplates and the flaps deployed, goal is to trap as much of the airflow as possible underneath. Going to try no gap at fuse later in testing.
3) Adding a KF2 across a flat plate for additional lift.
4) Using a stabilizer that I designed.
5) Using a standard cable tie for the tail gear. ?????????
6. Moving the 4 inch main landing gear as forward as possible.
7. Like all foam planes, build as lite as possible with an aft CG.
Specs:
1) E-Flite Park 370 1360 KV motor with 1300mah battery
2) 9 x 4/7 SF prop APC Experiment with a 10 " prop later
3) Large 4" wheels on aluminum struts
4) Dimensions: 34" wing and 32" Fuse
5) Weighs about 1.7 lbs
Being old school, plans were made of 8 1/2" by 11 to my eye scale to match what foam I have. I will use blue fan fold foam for stabilizer, depron for wing and end plates, formers, and Adam's foam board for KF wing and fuse.
After deciding width, easy assembly of the fuse with formers where elevator, wing slot and prop shaft are all parallel to each other.
Tail is set up so there is large movement in both elevator and rudder. Basically a 3D type plane.
Servos are internal and using very stiff wire and a thread at one end for clevis adjustment.
Next comes the wing. I used depron and re-enforced with a carbon rod and to make the KF-2 used Adams Readi-board which was epoxyed to the main wing making a good stiff wing.
Specs:
