hellcat287
Hi Everyone,
I've been out of the hobby for 10+ years and got back in this last February. I found the FliteTest site and have been very pleased with what you can do with DTFB. I've built several FT kits as well as a couple of scratch builds from plans.
Over the last month or so I've been reading on CNC and laser cutting machines to see if that's something that I could get into. I don't enjoy the current method of printing plans, transferring them to poster board, and cutting parts. I'd much rather have it done by a machine.
I'm struggling with going down the CNC or laser cutting route. I'm a little concerned with using a laser because of the possible safety issues including the beam as well as fumes generated. I do understand that these can be mitigated with a good pair of goggles, an enclosure / ventilation system.
So if I were to build a CNC, is it possible to cut foam with a precision router bit? Or do you need to use a needle type design (I've seen this posted in an post on this forum). Would the same CNC be useful for cutting balsa / hardwood also? Or would it be better to just go with a laser and just address the safety issues appropriately?
Thank you!
Thank you!
