Solved Compatible Remote Transmitters for EZ Power Add-On?
Jeremy97469
I am planning to get some of the EZ plane 3-packs to learn how to fly an RC aircraft. After starting with the 2 channel STEM transmitters, I plan to upgrade to the Spektrum controllers and would like to know if those are compatible with the EZ Power kits. If not, what is required to control the EZ airframes with the Spektrum transmitters?
Spektrum is a closed proprietary system and will not work with the EZ Power kits. You will need an EdgeTX/OpenTX radio with a multiprotocol module to connect to the EZ power pack.
Jeremy97469
Thank you for the information. Looks like the Radio Master TX16S Mark II will work with the EZ components. At the price of those, may decide to skip the STEM 2-channel remotes altogether and just go with the full size remote.
