nextmoneypit
I sadly summoned the genie when I fried my naze32 (didn't reverse the polarity, but accidentally plugged a JST connector 1 pin off, and connected the positive lead to the negative pin on the board
Anyways - luckily I had a spare. I'm to prevent that from happening I soldered a JST to the board. And to make sure the solder joint didn't short the pins, I checked for continuity...and my multimeter is beeping? I see zero evidence of a short though. Shouldn't there be NO continuity if nothing else is plugged into the board? Or is the circuitry on the board causing the continuity (I wish I knew a bit more about electrical stuff!)
