First flight didn't go as planned, prop torque caused it to pull hard left and down from my hand launch.
I cut throttle right away but a short cartwheel snapped the prop, and I didn't have a spare with me.
That was the only damage, I believe my foam version would of had a bit more cosmetic damage along the wing and nose.
I also had to increase the battery from a 1600 mah on my foam to 2200 on the coro to get the cg correct.
Once home I replace the prop and went to a small field in my development. Remembering to compensate for the torque roll, I launched again and was thrilled as I got control and watched it climb out fairly level.
A few clicks of trim and it flew very similar to it's foam counterpart. It was not as fast but characteristics of the foamy were evident, no bad habits, no tip stall great slow speed control. I brought it in and had a smooth landing.
I don't like to fly my larger models at this field, on the small side, and I have been seen tree trimming and roaming a back yard or two looking for my ummm toys.
