Update:
Through the Xmas hassel, I found a few spare moments and continued with the build of the mini quad.
The plush 10amp esc's fit perfectlty on the 7x7cm plate !
I used this to fit them:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8999
Great stuff ! Heat it up a little and it does the sticky job perfectly.
Some details of the center section.
I used the KK power distribution board.
Love these things .. easy soldering, re-usable and very light as well.
They are great to connect led's as well.
Board is a HK V2.1 flashed to KK's v4.7 in +mode
Some small rubber rings to absorb vibrations.
And used the same 4mm double sided tape to attach the small DSM2 RX on the board.
Total weight incl 850mah 2S lipo : 192gram
Time for the maiden ;-)
